Hi, My First Post….
I am in Prague Airport and i have 7 aircraft that give me the message “You need to purchase appropriate terminal to open a stand for this airplane”?
Any help?
Thanks CTS……
Hi, My First Post….
Any help?
Thanks CTS……
Hi CTS… welcome!
Can you give a list of the 7 aircraft and a screenshot of your Prague airport? For the screenshot, it is best if you can show it in 2D with the gate / terminal view (example below).
It’s either an F-class pax plane, or a cargo plane. How you get around this is you get on that exact menu (gate/terminal construction) and purchase the terminal or pier with the stands needed
Let me know if you need more help
Your right on both counts? More help please ![]()
Okay, did you find the menu yet? If not, then you can use the first screenshot @Rocky-Mountain-Air sent to identify the button (on the bottom of the screen). Then, you can use the filters on the right side (as visible on the second screenshot) of the screen to identify where the stands you’re looking for are (cargo is 3rd from the top, F-class is 2nd from the bottom. Hope that helps ![]()
Okay, it seems like you already have one of the piers with F-class stands, so that’s not the problem. It’s probably just the cargo then.
Hey!! Thanks both!!
