[ATC] - 3rd Stand Setting: Manual Assignment Only
Add a third stand setting so you have:
  • Red - closed to that class
  • Green - delivery manager will assign that class to it
  • Yellow - you can manually assign the plane but delivery manager won’t
Like current stand assignments with delivery manager off except delivery manager is only off for certain stands/planes. If a stand is open, you can use the normal way to manually assign a stand.
Let’s say you block C planes from your D+ stands. All of your D+ planes are assigned and you have extra C planes. Currently, you have to change your stand settings to get those planes in. Instead, you could manually assign the extra C planes without having to change your settings and change them back. This also gives you more control to avoid assigning fleet planes that you won’t want sitting there with maintenance or waiting for contract approvals.
Question: Couldn’t you just use the prefer schedule button that just got announced?
Answer: It’s possible but making the schedule would be hard. If you left all the stands green, you’d have to remember which ones to use for which planes (or not at all). OK at INN. Not so OK at GRU, SCL, HKG.
