What is your suggestion?
When an aircraft is on final approach and about to land, it will either float a bit and land a few meters after the touchdown zone or land before the touchdown.
It can be implemented in a way that when the plane is cleared to land on a runway or when it is assigned to a gate, it will create a random value within a range, for example between -10 and +10. If a plane has a value of -5, it will land five meters before a perfect touchdown and +5 means five meters after a perfect touchdown. This idea will not remove the ability of a “perfect touchdown”, it will just add a different scenario of a landing.
Why is this a good idea?
This would create more realism in the game, because not every pilot can create a perfect landing every time. This feature would create a type of “human error” in a way that doesn’t cause accidents. It can also be more fun for players to planespot the airport that you are currently playing.
Optional: Image or reference
