Best E plane to get?
Hi friends, i am expanding my fleet to larger aircraft and I cannot decide between the A35K or the B77W. can yall help me out.
I’m not huge into personal fleets, but which one do you like better? Get the one you want
A35K is almost certainly better since it has more range, is cheaper, gives more XP to level up faster and is only shy by a little bit for profits. It’s more universal though
It depends on your fleet needs. I recommend the A350K if you want to connect to almost any airport on the map, or if you want to earn more Wollars, I’d go for the B77W. Both are good fleet options, but if you’re looking for more operational flexibility without sacrificing too many Wollars or XP, I’d choose the B789 or the A339.
ok thanks boys
