Airline Name
GMG AirlinesIATA: Z5 / ICAO: GMG / CALLSIGN: GMG
Founded in 1997, commenced operations in 1998 (Apr. 6th), ceased operations in 2012 (Mar. 30th)
(Planned re-fleeting in 2012 never materialized, combined with financial difficulties)
Country of Origin
Bangladesh / People’s Republic of Bangladesh ()
Main Hub(s): Hazrat Shahjalal International Airport (DAC)
(For this airline, most types are already available in WoA.)Aircraft operated (already in-game):
Boeing 747 (-300, B743) - 2 former.
(Pictured below: TF-AMK - later broken up)This livery appears to have been an older, 2000s livery for the airline, hence the contrast between the logo provided and this livery. I don’t believe the B743s ever received the final, modern livery, which on the topic of it, will be displayed with this next aircraft:
Boeing 767 (-300ER, B763) - 3 former.
(Pictured below: S2-AFR - later broken up, known as N617SC at end of its life)Here’s another shot from the opposite side, just for the record:
(Pictured below: B-2496 - now known as 9H-CAD)That aircraft at the time still had a Chinese registration because it was in the process of being acquired by GMG - the photo is dated March 28th, 2010, whereas B-2496 was documented to have joined GMG on April 30th, 2010, where it became known as S2-AFD.
Moving on though:De Havilland Canada DHC-8 (-100, -300, DH8A/DH8C) - 5 former.
(3/2 for each variant, respectively.)
(Pictured below: De Havilland Canada DHC-8-100 S2-ACZ - now known as 5Y-DAC)Here’s that aforementioned older 2000s livery you saw on the 747-300 - it seems as if no DHC-8-100s ever received the later updated/modern livery.
However, before we go to the -300s, here are a few extra shots I wanted to include just for a reference:
(Pictured below: De Havilland Canada DHC-8-100 N816PH - later broken up)For context of the American registration, this aircraft was also in the process of being acquired by GMG, similar to the case of the 763 covered above - this photo was dated August 1st, 2002, whereas GMG acquired the aircraft in November 2002, where it became known as S2-ADJ.
Next, here’s an interesting alternative livery:
(Pictured below: De Havilland Canada DHC-8-100 S2-AAA - now known as VH-QQD)(Pictured below: Ditto, same aircraft as above)
Now, moving onto the -300s:
(Pictured below: De Havilland Canada DHC-8-300 S2-ADX - now known as C-FNXN)And of course, here’s the older livery once more:
(Pictured below: Ditto, same aircraft as above)A view of the other side for reference:
(Pictured below: De Havilland Canada DHC-8-300 S2-ADJ - later scrapped)And finally, here’s a slightly modified version of the livery, advertising the airline’s website around the nose:
(Pictured below: De Havilland Canada DHC-8-300 S2-ACT - later broken up, known as N8300C at end of its life)Now, onto the final aircraft type operated:
Aircraft operated (not in-game):
McDonnell Douglas MD-80 (-82, -83, MD82/MD83) - 3 former.
(2/1 for both variants, respectively.)
(Pictured below: McDonnell Douglas MD-82 S2-ADO - derelict)Here’s an example of that alternative early livery once more:
(Pictured below: Ditto, same aircraft as above)As for the MD-83:
(Pictured below: McDonnell Douglas MD-83 S2-ADP - now known as N808WA)And the alternative early livery once more:
I’d say this airline should be added as it had quite the history, serving as the largest private airline of Bangladesh prior to it ceasing operations, along with a notable selection of aircraft types, such as the B743 and DH8A/DH8C, and has a nice set of liveries - as a matter of fact, I really like their last, modern livery. (though the older liveries are also solid lol)
Besides adding to somewhat niche aircraft types, it would also add for more content for players to see at their airports, specifically Asian airports such as Bangkok, Hong Kong and Kannur. Since the airline operated past 2010, it should be able to be represented in-game as a map contract operator.Now, on the topic of Bangkok, the airline did run scheduled services to the airport prior to closing; usually serviced by their MD-80s with B763s on a few occasions. Nonetheless though, all of their aircraft should have the range to serve Bangkok, which would leave none out. As for their longer-range aircraft, of course the B743s and B763s, they would be capable of serving other airports in the region, such as MCT, HKG, and possibly others such as European airports or SYD.
Keep in mind though that all their 747s were removed from the airline’s service by the summer of 2008, so they’d likely fall a bit short of the “2010s rule”. All other aircraft types had at least one example operating past 2010, so they could appear as normal contract aircraft.So, in summary, I believe this airline should be added because it’d add more variety and content for lesser-used, niche aircraft types (see B743 and DH8A/DH8C), and because it has a nice selection of aircraft types - most of which can be added as normal contracts, with the B743s being a nice bonus, even if they’re just event only. It would also allow players to have more variety at their airports, especially those found in the Asian regions. Their liveries, especially their last, modern one, are also interesting and very unique, and I definitely think that it’d be great to see them represented in-game.
SOURCES:
GMG Airlines’ Planespotters.net Page
GMG Airlines’ Wikipedia Page
