HK runway usage
In Hong Kong due to there only being one runway for majority of landings you simply can’t fill up majority of the airport only I would say 30% of the airport is full even if you let the game run for a bit which is disappointing for such a big airport I don’t bother unlocking every gate because I can’t fill them. Need to change both main runways for passenger flights
Actually all 3 runways are pretty evenly spread for landing.
Each terminal uses the runway north of it for landing.
You start with mainly the center terminal, so using the C runway a lot in the beginning. Once you have the cargo and new terminal buildt all 3 will be in use.
Understand but the centre terminal and only uses one runway for landings for 50+ gates
Hi , even tough i unlocked the cargo terminal and opened 5 gates only cargo planes are landing close to cargo terminal there are no planes landing on that runway for example planes which are assigned to middle terminal, should i unlock more cargo gates for even other planes to land?
For the southern runway, you need to use the cargo stands which are south of the runway. The cargo stands next to the main terminal will use the middle runway.
