I am stuck DEAD in the water!
Just restarted WoA after a couple years off and see that V2 is out now. I have made a critical error right from the start, upgrading a gate to Medium and landing a medium aircraft on contract. However, the plane will just be sitting on the tarmac indefinitely as I apparently don’t have the cash to pay for the EQUIPMENT needed to unload passengers. Is there a way around this problem? In the past I could just reset the airport and start it over but now that is apparently not an option??? Is there ANY way to restart either the airport or the game itself? I have tried deleting the game and redownloading it and that does NOT work. FWIW, I do NOT have Game Center activated and play on an iPhone.
Uhhh you can just handle it knowing that it will take a while and not give rewards
Negative, it needs the ladder for MEDIUM aircraft which I do NOT have and it will not deplane ANYONE at ANY pace.
i just think u should just buy the credits needed for the medium stuff or like @Thatflyerguy said, just let the plane sit there until you can save up enough for the eqiupment
Uhhh what?
But you start with one of every kind of equipment?
That makes no sense, you should have at least 1 boarding crew and if they arenbm’t available for that M they are on another aircraft, you should be able to wait for them to be done, this game it is literally immpossible to be “stuck in the water” as you say
You can claim the free 500 wollars and watch the ad every couple of hours to buy the necessary equipment if you wanna do it for free. Or just purchase 10k wollars with 1 GP to get you out of it now
Which one of the symbols is yellow for you ?
Blue*, but does include a yellow exclamation mark, so technically correct
ok, but for @SWM1967 there should be one with an exclamation mark for his “stuck” aircraft.
Yes, when you’re missing a certain crew it shows a blue button with a yellow exclamation, I was just adding that because the way you worded it, it could be understood as the button being yellow
