Issue with PIA Aircraft Categories at MCT Airport
"Hi Team,
I am writing to report a specific issue with PIA (Pakistan International Airlines) at my MCT (Muscat) airport.
Currently, I can only see and handle the Airbus A320 (Category C) for PIA. Even though I have unlocked Category D and E stands, the larger aircraft like the Boeing 777 or other wide-body planes for PIA are not appearing in my contracts or traffic.
This makes the gameplay very limited for this airline. Could you please check if the B777 for PIA is restricted for some reason or if there is a bug preventing it from showing up at MCT
CT?
It’s due to the size restrictions for certain countries. Pakistan has been deemed a local/regional destination from MCT and thus only gets C class aircraft. This can be forceably changed like it has at MCT with the Gulf nations but the devs have to physically do that.
Same sort of thing applies with European airports with the irl D Class aircraft that did routes being locked out like Monarch’s 757’s to INN and BA’s 767’s to many European destinations.
The devs haven’t forced it to be restricted, all of them are by default, it’s just it hasn’t been put in place to allow those sizes which requires the dev’s to do it manually.
How can I contact with developer.
It’s likely best to suggest it here on the forum with some evidence showing that said larger types are flown in and out of the airport. I’ve done one for BA’s 767’s along with Monarch’s 757’s and United/Delta’s 757’s not being able to do the shorter range trips.
It would be done under World of Airports Game suggestions and you need to fill the template in to get it accepted but if you do it fully I can’t see the devs not considering it.
Having had a quick look on JetPhotos they used to operate the A310 on the route to Muscat.
So a 772 even if a little large would potentially fit the airport, at least maybe from the capital.
