Should I have the minigames enabled or not? In large airports? Or only in small ones?
I think it is only really good for small sized airports, for the beginning of an airport, it definitely helps a lot if you’ve trained a bit to get that plane 100%
I’ve mastered it for a while now, except for the ice remover, which is very tedious, but I was asking about the big airports because after so many planes arrive at the same time it gets tiresome.
Not worth it in my opinion except when starting an airport off. It’s also handy if you have a couple of xp pips to tick into another level. Aside from that I find it quite tedious and not all too realistic, though I do prioritise the parking over all others ![]()
