Hi there
I seem to be having back-up issues as my plans are to taxi to the take off runway, and won’t cross the landing runways, causing a back log on the taxi way at the original terminal.
Hi there
This is not a technical issue.
It’s part of the game play, right now the aircraft are generally ordered in the sequence you accept them or release them for departure.
If you are only using the old terminal you need to be careful how you do this so the back ups don’t happen. It can be done quite easily with a bit of patience.
Devs are working on a partial solution for it generally but right now you just need to not accept or release a ton of aircraft in a row.
Please use the bug reports appropriate thread to report such things. As a result I am locking this thread.
