Saw this pop up today… blank owner…
I’ve had it before, I think it’s a user who hasn’t registered a username.
I think you should shift this topic to Bug reports/General Discussion.
I’ve moved it across to bug reports for you, @Rito is right. It might be a bug that may need investigating.
The first farming bot ?
Stealth
I saw the same plane in INN, not the same callsign, mine was PF2021 from North Pole (NHP). I think it’s like a holiday plane event thing or something.
Was it the ‘Merry Christmas plane’’ or something else?
I think it is.
Was it coloured with red and green?
I looked into it a while ago and found that it’s not a bug because when I looked at the connections window, there’s a tab for North Pole NHP with just 1 plane(the B738 with red and green livery).
Yes.
Yes, Merry Christmas plane is normal/special.
I was referring to the plane with no call sign with tail number NPRW (NPR is a radio program in the US).
