UI / ATC transferable aircraft
What is your suggestion?
- So everyone wants to move their aircraft between airports when they want to achieve better economy and meet the demand!
- so we would have a transfer button in the fleet aircraft.
- Planes would Travel between your desired airports and instead of travelling back they can be stationed there for your use.
- Aircraft for instance if you want to them to travel to your airport they will need to travel between different airports
- Just like in pocket planes if you want to get your planes from one destination to another it will cost you money to get to that area!
- A & B aircraft will have a harder time to get to places because of their size.
- C & D Aircraft will have some hard times but notably easy travel.
- E, F & G wont have any hard times unless their destination is too far!
= fuel will be apart of the costs for them to be flown.
= distance of travel between airports for different airplanes. - If lets say a DHB or ATR67 wanted to fly from SYD - LHR
= They would need to fly to non-playable airports to get to their designated airports.
SYD - CNS - DRW - DPS - SIN - RGN - PAT - HYD - DOH - CAI - ATH - FLR - BRU - LHR
So the way it would work is the more destinations and places for your aircraft to land to get to your Airport will add to the cost of getting there. Just like pocket planes, you customize your route and then see if you want to transfer that plane.
for larger aircraft that can do less destination stops, would have a larger cost for fuel depending on aircraft.
Different size aircraft for fuel costs ( 1 way trip )
A&B = 3.5K Wollers / C = 5k Wollers / D = 8K Wollers / E = 10K Wollers / F&G = 15K Wollers
Each stop for that certain aircraft will Vary on the size that plane can land and take off
A-B airports = 100 / C-D airports = 500 Wollers / E-G airports = 1K Wollers
so for reference from that trip i showed you for B aircraft it would cost you roughly 10K Wollers.
Keep Maintenance logs in mind!
aircraft that are too old and need costly maintenance wont be able to fly to your destinations and would most likely need to be scrapped or sold!
Why is this a good idea?
- Because players want increase their revenue to build up their fleets in other airports!
