Path finding D Cargo Stand PRG
Platform:
Android
Game Version:
3.7.0
Airport:
PRG
B763F use RWY 06/24 for taxiing from intersection point with RWY 12 to stand E 3A.
Additional Notes:
If another Cargo plane stops at holding line for RWY 24, approaching plane stops at the middle of the RWY and taxiing process gets stucks.
And also A346F
I think it has been done like this as it is a G-class stand. The An225 would be too big to use the normal taxiways due to its huge wingspan so the devs made it like this so it won’t block taxiways or clip other aircraft.
For me, I’ve just disabled the stand for anything below G-class, so it’s basically an AN225 only stand
Got the same problem today with a cargo!!
Any bugs involving cargo lanes blocking the route and softlocking are unimportant, E3 is only usable when the entire cargo terminal is empty so it’s judt for the first startup since the remodel that itll be an issue
Why would you be using the E3A when it blocks the entire cargo terminal? It’s engineered like this because the An-225 has to take this route, so I guess the devs built this pathfinding into the stand itself.
the delivery manager used it
