Progress rewards resetting
When SYD comes out, will the progress rewards reset? I know with have airport unlocks in the rewards now it would be hard to add it the LHR pass of current players without resetting it. But also, pre-2.0 unlocking airports was an achievement, rather then being on the pass, so unlocking airports was not affected by a reset. Now if it is reset, it will also reset progress towards a new airport. I don’t know what to expect with the update so close.
Nope! Passes are never reset. It will replace one of the current levels at LHR, likely level 80, and more levels will be added. If you have already reached that level you will immediately unlock SYD for free on release.
Are you sure about that?
When LHR came out, they added some levels to SXM and you had to level up (I believe) three times to unlock LHR.
But if that has changed, I simply might not have heard about it.
they won’t go back, they will add levels and make that part of it.
I see. Thank you.
I think it’s more likely that they add lvl81, 82, maybe more and on 1 of those levels SYD will unlock. I think at lvl80 you get a free A359 so I am 99.9% sure that that won’t be replaced with SYD
Yes, that is exactly what happened at SXM.
I absolutely agree with you.
