Why BKK don’t have parallel landing system? Any specific reasons
Unfortunately, it is not divided randomly or 33%-33%-33%. Instead, each RWY is assigned to a gate. If you are starting from scratch and want to use all RWYs, you should unlock them according to the above scheme.
No, I meant to say why not parallel landing on 20R & L. Why there is a gap between their landings? That’s my real question
I don’t why but the runways should be able to handle 3 simultaneous operations. I get with GRU the runways are too close.
20R and L are too close to each other to land at the same time.
How?
It says they are 2200 meters apart so I don’t see the issue.
And even at GRU they dep and arr simultaneously
I last saw a QTR 777 roll out while a 320 was landing
Well GRU has a delay a plane has to touch the ground while landing before a departure can start because of how close the runways are.
But in real life they don’t do that
Planes start rolling and lift off while others are already touching down
You check the multitude of live cams on YouTube
Just 2days ago,I saw QTR 77L roll out and before it started rotating, a LATAM 320 was touching down
I really think the devs need to re-evaluate this
You are right! I just found this video where at even GRU there is simultaneous takeoff and landing that is not delayed. https://youtube.com/shorts/B5kLN1hVV80?si=uUkJ-coFoWipwKGn
I agree. Devs need to look on into this
Do we need to email them or do they read the forums ?
Probably forum but they made it clear they’re not really interested to make the change
I do hope they change their minds
