Hello,
I apologize for any grammar mistakes, the text was translated by google translator, the original is below
I started the game again after a long time, excellent move forward
So far I only have the basic airport, previously I also had Prague unlocked.
If any of this has been addressed here, I apologize. I didn’t read everything.
Question: when landing with your own plane, what is the reward? Technical inspection?
Reminders:
1 - Contracts: if I look in this tab, why doesn’t the red dot disappear? It should disappear after opening and appear when there is something new here (e.g. resuming the generation of a new contract)
2 - after landing and adding the handler, the exclamation mark is still lit, which should only be when the technique is used. It’s confusing and I often turn off my flight card
Suggestions for the future:
A - when looking from the camera on the plane, add a camera turned behind the plane, or make the one on the rear wing turnable
B - highlight planes - add the option to highlight only the path without the blue outline of the plane
C - view from the tower - centering the camera on the object. Option to turn off, or (a better option) to set the option to adjust the zoom (slider). The camera captures the marked aircraft very closely
D - Sort active contracts by time until arrival. Closest to furthest.
E - option to rotate the 2D view and move the edge more to the center of the screen
F - add bad weather and runway closures? storm/snow
G - malfunction at start and need to return to the gate?
H - add the option to cancel the size on the stand. For example, I have S and M and I want only M there
Good work
THX
Off topic: Don’t you know the same/similar game where you control stations and trains? Thanks
Ahoj,
Omlouvám se za případné chyby v gramatice, text přeložil google překladač, originál níže
Opět jsem hru spustil po dlouhé době, vynikající posun kupředu
Zatím mám jen základní letiště, dříve jsem měl odemčenou i Prahu.
Pokud se tu něco z toho řešilo, tak se omlouvám. Vše jsem nečetl.
Dotaz: při přistání s vlastním letadlem, co je za odměnu? Technická prohlídka?
Připomínky:
1 - Kontrakty: pokud se do této záložky podívám, proč nezmizí červená tečka? Ta by měla po otřevření zmizet a objevit se až zde bude něco nového (např. obnovení vygenerování nového kontraktu)
2 - po přistání a přidání handlingáře pořád svítí vykřičník, což by mělo být až když je možnost použití techniky. Je to matoucí a často si tak vypnu kartu letadla
Návrhy do budoucna:
A - při pohledu z kamery na letadlu přidat kameru otočenou za letadlo, nebo udělat tu na zadním křídle otočnou
B - zvýraznění letadel - přidat možnost zvýraznění pouze cesty bez modrého obrysu letadla
C - pohled z věže - centrování kamery na objekt. Možnost vypnout, nebo (lepší volba) dát do nastavení možnost nastavení zoomu (posuvník). Kamera zabírá označené letadlo moc z blízka
D - Aktivní kontrakty seřadit podle času do příletu. Nejbližší, po nejvzdálenější.
E - možnost otočit 2D pohled a posunout kraj víc do středu obrazovky
F - přidat špatné počasí a uzavření ranveje? bouřka/sníh
G - porucha při startu a nutnost opět na bránu?
H - přidat možnost zrušení velikosti na stojánku. Například mám S a M a chci tam mít pouze M
Dobrá práce
Mimo téma: Neznáte stejnou/podobnou hru kde ovládáte nádraží a vlaky? Díky
