[UI] - Change in Flight Side Panel Order
I suggest slightly changing the flight side panel that displays active flights. The change concerns the order in which flights appear in the list.
Before version 3.0.0, the list of flights (for actions such as stand assignment, landing, handling, or departure) scrolled from bottom to top.
Now, it scrolls from top to bottom β€” meaning that flights that arrived later are displayed at the top.
As a result, aircraft that returned first from their routes end up at the very bottom of the list, regardless of whether they are requesting landing, handling, or departure.
After aircraft complete their routes and return (depending on flight duration), they should appear in the flight panel starting from the top β€” beginning with the first aircraft that arrived.
New returning flights would then be added below the existing ones.
:clipboard: Example:
Current: the newest arrivals appear at the top.
Suggested: the earliest arrivals appear at the top, and newer ones are added below.
This change would make the flight list more logical and user-friendly: landing, handling, and departure should naturally prioritize aircraft that arrived first.
It also improves convenience, especially in large airports with many contracts β€” you wouldn’t need to scroll all the way down to approve landing or handling for the first-returned aircraft.
will consider with team. thank you for your feedback
We need this… Or adding Filter for more Flexibility… :100:
Hi kubasan, please also consider that if this suggestion will be implemented, the delivery will always prioritize the flights at the top of the list which are the first to arrive at the airport rather than the one in the schedule. For example, one game session the first in the schedule flights are already handled and took off, and the second in line was not landed or handled say you need to close the game for some reason so they remain at the top of the list, now if the first in line return and the second in line is still at the top of the list it will be prioritized over the first in schedule. This is to give chance to those unhandled flights to be landed and handled. Currently if you do not handle all planes in one session, the delivery will prioritize the first in schedule so the later flights will not be handled again.
Yeah, that’s right… It’s definitely going to turn into a vicious cycle…
