[UI] - handling process
adjusting the current handling process to
  1. Have all planes handle the same, in regards, boarding/baggage loading happening simultaneously
  2. Having fueling time increase slightly to reflect realistic fueling times
for boarding/loading would be the same such as with planes like most of the C planes, with the exception of cargo planes and the DHC6.
Fueling would just take a bit longer as the current fueling time is too short in comparison to real life procedures
baggage loading happens after passenger boarding has started. In real life, especially for larger airlines with connections, it is not ideal to load all bags as passengers could miss connections and bags are not permitted to travel without the passenger boarded on the flight. Currently in game, most pax planes (apart from C planes like the 737/32X/19X) load bags as soon as the plane is done with offloading which does not look or feel realistic.
In regards to fueling, an E or F plane (with the exemption of cargo) will finish fueling in about 2-3 minutes during a 15min in game turn around. Most fueling procedures are finished before or during boarding depending on the type of turn.
These suggestion are more to add realism to the game.
B planes
D plane (accurate handling style)
Editing this for reference with the newest update
Now with the 3.1 at SCL, just noticed that a B463 fueling takes longer than an A318. I think the fueling time for the B463 is fine but the A318 is unrealistic
