BKK - Pre-release discussion
I still remember, and I think I understood correctly, that the next update is a “special” update, but not a new aircraft model or a new airport. As an update BEFORE BKK. That would fit in with the timing of BKK being released on 25 October with the anniversary and the “Meet&Greet”.
At least I can’t imagine this event without an update :wink:
Don’t expect too much, it’s hard to say if there’s a delay👀
When they said no new model, they were referring to an aircraft rework. Im pretty sure the next update is still 2.5
2.5 should be BKK only yeah. After that IAD remodel, 777 family remodel, ui revamp and mistery or SA airport (after BKK the things are in no particular order, since devs can always change things around)
Actually it’s more likely to be
BKK-UI-777-IAD-South America
Where the mystery airport sits I’m not sure. Then there is DEL which might be back on the table
Kuba said on the DevBlog that the new UI comes together with IAD
“IAD will be Part of new UI”
Do you know anything else?
But we don’t want to turn the BKK pre-release discussion into a general discussion here
Isn’t DEL mostly done with some minor changes needed to be done? I seem to remember seeing you or UK saying something like that, maybe I’m hallucinating though. If unity has finally backed off with their licensing thing maybe we could have a 3rd surprise airport this year if what I beleive was said is true
The model is essentially done but none of the pathway work etc are build out of routes etc have even been started
Id like an Indian airport honestly.
More M connections for muscat lol
I hope UI isn’t changed that much as it perfect as it is. And as saying goes don’t fix what ain’t broke.
I think they are just making it look more modern. Nothing much! Looks better tbh!
If you re-tread the q&a a bunch of new features are coming with it too
Yeah let’s call it UI V3 or maybe V4 at this point, it’s definitely a big makeover. And while the current UI is pretty good, there are some pieces that would make it even better
I hope the 737 family can be perfected.
The devs said that is still a while out probably after all v1’s
Yeah the 737’s maybe last. That’s a massive amount of work. Because you have the classics, NG and Max,
733,735,736,737-7,737-9 and er
Max7,8,9 and 10 with the special Ryanair 200 option
Naming conventions changed to keep it clean, but you get the picture
I wouldn’t be half surprised if the 737 gets split into its various families. You’ve got all the different winglet configs on the classics and NGs on top of already a more sizeable line up when compared to the A320 family.
Plus 738. Also perhaps 1 and 2?
I won’t be surprised if the release the updates family by family; first max and ng, then classic, then original
BKK-fokker-UI-777-IAD- south america
