Sent three A35K from my MCT.
Took a little reshuffling of contracts, but accepted
thanks for cooperation
Hi,
Any chance of B77w orB748 to NGO. Thanks
My user is Tvsarah
Hello! Iāve sent you a brand new A21NY from SAN.
If you have any planes in size D available I will gladly take them, to make best use of the D stands of SAN so I can level up as well ![]()
My IGN is the same as here, SabNik3001
For sure
Iāll send them from my IAD tho, Iāve run out of contract slots at SXM again
Thanks, Iāll send you some 757s in a day or two ![]()
Thanks Denis, Iāve just accepted the contract. Can I send you anything-Iāve got mostly 320ās at the moment?
For sure! I can accept them at PRG, IAD, MCT or SXM. Just sent you the 77W now as well ![]()
The A346 contract and your 752s are almost finished between SXM and LHR. Would like to keep it going, do you have capacity? I could renew the A346 or I also have a 77W available. Let me know.
For sure! I always renew contracts, thatās not a problem at all. Just bought more contract slots as well, so Iām open to receive more ![]()
Sure you can
Want me to send you something back? Got a 747 at PRG that I need to send somewhere
Hi everyone, Iāve decided to cap the number of received contracts at 40. SXM is quite a small airport to work within the constraints of, and itās already taking me longer than I want to do a single play session on the airport. I can provide handling to your aircraft at my other hubs, which are PRG and SCL, and to a lesser extent GRU, MCT and IAD. I will also continue to send planes from my SXM, which will become the main purpose of this post from now on. Speaking of sending planes, my backlog is finally diminishing, so new orders will likely come quicker than before.
If you still have anything available i am accepting ac at SAN.
Perth Air
Got it, Iāll send some tomorrow
Hi everyone,
I havenāt had much time to play SXM lately and thatās mostly because it just takes too long.
Itās become a lot more than the small, quiet, scenic airport that SXM is supposed to be, and thatās probably because I have over 90 connections here. It sometimes takes me over 3 hours per play session just to handle player connections alone, and thatās not an amount of time that I have or want to spend on a single airport.
As you could already probably tell, Iām not a very consistent player at SXM, which I think is a shame because it is a really nice and picturesque airport. But given that I still have 7 other airports to manage at this point, a change is needed.
First of all, I will once again be reducing the number of inbound connections to 30, which means I might have to cancel some connections to do that. SXM is not an airport where Iām providing fast and reliable turnarounds. If youāre looking for that, then I canāt help you here. Optimistically, Iāll get to play the airport 2-3 times per week as opposed to daily (PRG) or almost-daily (SCL, MCTā¦) activity at my other hubs.
Iāll also cut back on my SXM fleet and renewing outbound connections to a lesser extent.
I guess Iāll see if that solves my problems and Iāll get back to you later.
