Survey: Grouping of liveries in WoA
Quick question Charlie, this also including the 747-300? I have a few liveries I’d like to throw into the ring for that, namely Saudi, PIA and TAAG. Thanks again :smiley:.
Thanks for clarifying :grinning_face:
Just a question, will the older 747 variants as well as the md11 work like the 762 or dh64, where most or all of the pax liveries be events or pass rewards?
Yes as the major thing will be to add them as playable at Kai Tak or at least most of them.
Am I understanding correctly that the Dreamlifter is also confirmed by the looks of the B747-400LCF? Are the engine options purely for the player planes to have options when purchasing?
Let’s hope they’ve done BA B747-200 in Chatham Dockyard livery then you can have them as well.
work on all B747 variants model,
You sure about that?
I really hope so!
I’d love to see the 747-400D and -400M
Charlie is a developer and he knows what he said
Sorry to be a pester Charlie but regarding a bit of confusion over the -200/-300/-400 combi variants, are those included or are they a later addition. Not pushing for them in any way, just want to clarify before I swamp @ukplanespotter757 :rofl:
Edit: Just also scrolling through, the -100SR is that going to be its own model or will it be thrown in with the normal -100, similar case with the -400D to the -400? Thanks again.
Edit NO.2: Having gone down the rabbit hole of cargo 747-200 variants I might’ve lost my mind, I wanted to ask yet another question regarding the converted SF variants. They’re not on the list here but have they been lumped in with the 747-200F or are they not included. Again, sorry to be a pester but I’ve been going back through some of my suggestions and realised they’re all sorts of different variants. Thanks :slightly_smiling_face:.
Also, found this in my scouring of Google. Shows the ranges of the -100 and -200 converted and normal freighters. https://www.boeing.com/content/dam/boeing/boeingdotcom/company/about_bca/startup/pdf/freighters/747-200F\\\\\\\_-200SF\\\\\\\_-100SF.pdf
Sorry to bother you but I dont think the link works
Darn it doesn’t :angry:
Edit: https://www.boeing.com/content/dam/boeing/boeingdotcom/company/about_bca/startup/pdf/freighters/747-200F\\\_-200SF\\\_-100SF.pdf
It fails to work as a link but if you search google with it, its the only one that appears and does work. Weird. Makes for some good reading though :smiley:
So this is why there’s been so many 747 liveries lately
Hello,
the 100 SP version will have its own model as they have different Flaps system
The pax / cargo version will not be part of the update at this moment (so far I know)
I will have to check on monday if the converted versions will be created or not (I think those were not considered in the project goals)
Thank you for your reply. I just want to make it as easy for the mods and ultimately yourselves as possible :grinning_face:.
I hope the M and D versions will be included in the future. Gives a bit of variation to the models
Will the LCF be included? I need to see that parked at NGO :zany_face:
LCF is included in the lists Charlie posted (but for some reason with both PW and RR engines, even though all four of them have PW as far as I know).
Or just ask ChatGPT :joy:
