Can anyone tell me where th contracts for air austral are? I have looked at reunion (where google says they are based) and France where WoApedia says but I can’t find it, is it not possible to get it at Washington?
You can get from France and reunion from BKK and any airport after BKKs release (excluding CNN)
Oh ok! Thank you
Still baffles me that they can’t be attained at any of the previous airports
You can get it at GRU from CDG and ORY
from IAD? i checked and i cant i spent like 5ish minutes just looking around for it (unless i was looking at the wrong places which is most likely)
No not from IAD
I use the @TechnocraticAviation WoApedia 3.4.0 spreadsheet to keep progress. This week all of a sudden the numbers on my list and the number of unlocked planes in WoApedia were no longer matching. Checked the most recently unlocked planes and found I had it ticked them off in the spreadsheet, so it wasn’t that.
Went through all of the airplane types again to to see whether the number shown in WoApedia matched the spreadsheet. Found a couple of discrepancies which I thought were strange. After updating spreadsheet showed 1237/1866 liveries. WoApedia itself shows 1241/1866 liveries. So I wondered whether the total number shown in WoApedia was incorrect
Went on to check numbers per type and found that spreadsheet and WoApedia show the same numbers. So as per the screenshot below/attached I have 27 A319s, 89 A320s and 25 A321s ticked off in WoApedia and those numbers are identical in spreadsheet. But when I add all the numbers from WoApedia, the calculator shows 1237 in the spreadsheet and not the 1241 from WoApedia.
Anyone else experiencing this? Did something change?
I also have a deficit of 4. I’m at 1853/1866 but have 17 left to connect which will get me to 1870. It has to do with legacy liveries which where removed after you collected them.
Hi, the developers have hidden some liveries from view, so the WoApedia count may be higher what what you can sum from each individual plane. Personally I have 5 hidden planes and currently I am missing 11 liveries despite WoApedia showing 1860/1866. These 5 liveries used to be collectable but are now unobtainable. They are as follows:
- Air Hong Kong A332F (DHL livery) - Not the DHL subsidiary livery we have now, removed in 2.5.0 (roughly)
- Emirates B77W (Expo 2020 (Mobility/Blue) livery) - Removed in 2.6.0
- Emirates B77W (Expo 2020 (Sustainability/Green) livery) - Removed in 2.6.0
- Emirates B77W (Journey to the Future livery) - Removed in 2.6.0
- Singapore Airlines B789 - Removed in 2.4.3 (roughly)
It is possible you may have obtained 4 out of 5 of those liveries so please have a check with your memory
