#15 - Connections threads
Hi everyone, Quick update
As part of the site restructure, we are looking at moving existing threads over to the new section for World of Airports.
The first one of these are the Connections threads, the old Categories have been closed and moved to a single new category
New Connections Category
As a result we can no longer have individual categories for each airport. So searching and new threads have to be tagged instead.
When searching you will see the category header and then an option for tags. Click on that and it will show you the available options so you can select your airport.
For new threads, create the thread as you would before and add the tags “Connections” and LHR for example. So that they can be slotted in and be found.
There are currently 583 threads (at time of writing) so using the tags is the easiest way for you to find what you need.
I am sure it will take some adjustments, but it will be the way we manage things as we move things across so you will need to get used to this format as we don’t really have a choice
Enjoy…
It’s like discord now… :+1:
We try very hard to avoid that LOL
I suggest adding receiving and sending tags as well @Thatflyerguy . It would be good for people to make clear whether they are sending planes or receiving.
I don’t seem to be able to reply to the Sharepoint threads (for any airport). Is that a known temporary issue during the switch to the new format or is that a bug?
Or am I just blind and missing something? :sweat_smile:
Sorry about that. I thought there was a default setting on that category, but apparently not, should be fixed now
This topic was automatically closed after 28 days. New replies are no longer allowed.
