So, farewell guys! We will miss you and hopefully see you again!
It certainly helped me with the levelling up.
On the other hand those stands now double as PAX stands so you get get some extra C pax in their
Interestingā¦
Iāve already maxed out MSY in 3.0! ![]()
First of all, thank you developers for you amazing work!
After about half an hour of play I can already tell the wait was worth it!
About GRU⦠Does somebody know or has somebody figured out of dual use of the runways for landings / takeoffās is possible?
Filling GRU with just 1 runway feels impossible at the moment, but maybe Iām missing something!
Cheers and thanks once again!
Just a quick note, if you have B757ās that were scheduled into an old M gate at INN pre update, the glitch on push back so the game needs resetting.
Loving the update so far though I have to say
Maybe its just me not being used to it, but.. The new UI is really confusing. By cramming so much data into it its really small.
- no color difference on 2D view
- really small icons
- cant filter out just approaching planes, that are ready to land, shows ton of planes, that are waiting to be assigned non existing free stand
- way more expensive ATC
- stand blocking other stands is really confusing
Good change is when it feels new, but similar enough. I feel like this crossed the line into not being similar enough.
I“ll probably get used to it. I just wanted to voice my first opinion after playing for like 30 minutes.
If Iām not mistaken, it should work just like LHR: 1 landing-only and 1 takeoff-only runway. Thatās also how it works in real life.
You can now get a Saudia E170 at BRI
Also you can now have maximum 5 D class planes at BRI (2 of which are the OG 2 L stands)
There is 8 D Stands but using some cancels out others
Overall nice update. Only 1 annoying thing.
- its difficult to seperate the already assigned planes too stand and can land with the ones that havent a stand. I think at a small colored dot on airplane card will fix it
I didnt use atc
Bad paiting but that blue dot will help to differentiate the two
Hmm.. if thatās true, GRU will be a lot more challenging than LHR for grinding.. Every plane needs runway clearance, meaning you canāt leave your phone next to you while you wait for the airport to fill up with planes..
Only way to solve this would be to āābuyāā the ATC ground function next to approach.
Anyway, really satisfied with this update!
Hi there! Thanks for the update, and overall Iām enjoying the new UI. Really like the slider to assign crew instead of tapping the + sign ten times. Oh, and the ability to sort planes by your own and other playersā is amazing, thank you so much for that.
I have a couple suggestions that relate to accessibility:
- The option to sort the planes on the right from bottom to top, as it was in the previous version, so that if there is, for example, only one plane requiring action, its card would be in the bottom right corner, not top right. I have a rather large screen and it is quite inconvenient to tap in the top right to select plane and then tap all the way in the bottom centre to perform an action.
- Less importantly, the ability to scale the UI would be good. Maybe Iāll get used to it, but at this moment itās a bit small for my eyes and fat fingers.
- Lastly, I donāt know if itās intentional or a bug, but after the update the game no longer seems to recognise my phone orientation.
And I also have to say, Iām not a fan of the new āLine up and waitā feature. Itās literally just adding one more click to every plane for absolutely no benefit. I cannot think of a situation where it would be useful. Is this just to force people to use the automated departure ā the price of which, I couldnāt help but notice, almost doubled?
Canāt find the contract for the CRJ2 Austrian and Lufthansa Cityline. Are they not in the game yet?
They should be event liveries.
Could be indeed. Letās wait for the livery list soon
and this update was supposed to reduce the amount of unnecessary clicks
And thereās no option to turn it off?
I can only think of it being useful for SXM and INN if we were able to let C/D planes backtrack/line up, and. Let A/B planes take off in front of them
If there is, I didnāt see it.
