same here
Thanks for clarifying!
Only at MCT?
I’d bet they can reach IAD, maybe SXM and MSY but that’s a stretch for Icelandic 757s, idk if German ones would reach
I check and it looks like IAD has United and Delta 757 contracts available for German airports, however there are no Condor 757 contracts. It feels like the current 757 contract availability from IAD is a bit sparse, as there are no medium haul (Such as ORD, IAH, MCO or DEN) or even short haul domestic 757 contact routes available for United/Delta liveries even though the A321NX is available on the same routes. From what I have read, some liveries are still a work in progress or coming later on.
That’s right, there are still some liveries that were not released due to an error, but they will be released at some point in the days.
Try to clear cache and all data then try open the game again
I have a United 752 to EWR?
You’ve probably had it for a long time, right? I have 752 to EWR or JFK too, but they’re not available to purchase anymore, so be sure not to cancel them.
This was back when the 752 was a C plane
Now that it’s a D the distance requirement changed
I’m surprised to see a 767F available from MEM but not a 752 from IAH or DEN
Ahh ok, better not cancel it!
Yeah and from MSY i would have loved a fedex MD11 to IND or MEM!
I told them about it. Tbh i wouldnt mind if it only had winglets but E45X also has tail fins and our E145 united evo dont have them unfortunately
CNN airport:
The first time the planes were taking off and landing at RW07.
I notice when I played the CNN the second time, the wind change and planes were taking off and landing from RW 25.
is this update only effects on CMN airport but not the other playable airports? Please correct me if I am mistaken?
CNN is a first of its kind by being both the first generic airport and the test bed for wind direction landing
As it seems to be going well, it appears it will be applied to other airports, just not sure how and when
I have the 752 from SAN to SEA and DEN. I hope these larger aircraft can go on shorter routes more in the future
I saw some people did not get well with this change, but I found it is very interesting to play around different voice options from the device’s TTS menu… ![]()
I suppose to have the previous built-in voice as well and that could solve the problem for many people.
If you change settings in the TTS menu, it is very interesting so I do think this one works great.
At CNN does the runway switch as i noticed a runway change when I played the second time
Yeah it changes depending on wind direction
Idk how to do this
I don’t even know what this is really lol
Go to settings, probably accessibility, and then look for text to speech.
You should have several voice options to play with.
