There goes my hopes for contributing ![]()
guys
a320 is planned to be released in 2.2.4 (and even a319 from above pic)
pic credit sobbing_ in discord
Lol, the other devs looking at the dev who published that timeline…
So we’re looking at the A320 and new A319 variants I take it?
Very slightly disappointed the A321 isn’t being released together, but I get it. It’s will very cool!
Well to be honest with you the A319 CEO (not NEO) is currently fine on what it looks
you mean current version ?
its v2 it doesnt have rotating fan and retractable landing gears
Yea the current version though loads of aircraft have V2 like 737 or A300
No aircraft have retractable landing gear…
That’s a good point, unless they’re just adding more variants, then it seems fine to me.
no, v3 models have
devs havent just enabled them.
Actually he is right, I remember that before 2.0 the Devs said something like that they will added animated gear once all V1 aircraft was remodeled I also can see some closed doors on some aircraft. So basically yes V2 aircraft dose have animated gears but for some reason they decided to remodeled it the 3rd time.
v2 doesnt have retractable landing gear check 319 you cannot see doors and 738 amd MAX8 dont empty space for landing gear to inside the fuselage like v3 b453 has
look at the nose gear of both
V3 models are future-proofed through the gear bay doors being left open. As stated the devs will remodel all remaining V1 models to V3, only then will the animation be made.
And your basically showing a BAE which is V3
@Ecoaviation yeah you said v2 has animated landing gear but doesnt have i used v3 to compare how devs want the models to be .v2 doesnt have landing gear bay check properly
i know BAE is v3
@L1ttleH2009
v1 and v2 will be upgraded to v3
The V3 animations will start once the final V1 is remodelled, I would assume for the V2 → V3 models the animation would be made along side the model.
Even then hopefully they will also add the A320 and winglets and Non winglets as the cockpit looks ugly compared to real life especially with some liverys like this for example
I did not expect them to the the a318 but it’s always welcome😁
Also a question though, I know that not all variants are coming in 2.2.4, so which ones will take a bit longer?
