[ATC] - Bari E stand 313
Bari should get an extra E stand at the main terminal in accordance with real life
An extra E stand would be added that would block 310
Increases realism and adds better capacity to Bari
IFATC Info - Airport Gates
312 is also missing
Hopefully it will come with shared stands
Were still missing stands 201/203/205 and 312 that can handle C planes
So now we have to add into BRI:
→ 1x E stand
→ 3x shared C stands
312 should also be a combined stand as poste air cargo sometimes parks there
Tbh I wouldn’t mind the devs modifying the current cargo stands to become pax stands and let 204/202 and 312 be combined with cargo since there aren’t a lot of cargo airlines flying to BRI
I do hope the devs consider updating parking stands for certain airports along with all this new stuff they’re working
Wait…
So the 4x A → C Cargo stands aren’t actually there?
And stands 102/3/5/7 are slanted
So if I’m correct, when Bari is remodelled, there will be 33 stands with the 2nd apron having 5 stands that can be used as 3x C → D or 2x C → E
Stands 311/2/3 will be a shared stand, with 313 being an E and 311/2 being C
Someone check this is right, because if it is, Bari would be able to expand ramge of airports it flys to and contracts available
The photo shows stands
102 / 104 / 107 / 109 /
101 / 103 / 105 / 106 / 108, 110 /
201, 202 / 203 / 204, 205 /
309 / 310, 313 / 312 /
401 / 402 /
Bari already got a remodel
Right now it just needs a stand update
Wait, where did you get the top image from?
I believe this document is the source. It’s a ground chart of the airport circa 2011 (though I believe still valid).
I generally hope BRI is one of the next apron updates next to SXM
I hope whenever Bari is redone that they add those double parking stands at 201/202 and 204/205
And 203 :grin:
