[ATC] - Sydney Stand optimisation
ATC – Sydney STAND
The gameplay of this image in Sydney urgently needs to be optimized, with the addition and correction of compound parking positions. Tower realism
Add a composite parking spot, which can also be used as a passenger parking spot in the freight area. Please make the parking space across from the international terminal available as soon as possible. And open the cargo space at the domestic terminal.Starting from 16R, Departing from the domestic terminal.
It will greatly enhance the playability of this picture of Sydney. More realistic.
From the live screenshot, it can be seen that the freight area has a composite parking positionBoth passengers and cargo can dock.
I’d like to add these areas as well are missing parking stands in the game
The DHL parking stands
Remote (combined) stands for RON flights and maybe military cargo?
Additional Qlink stands at the Domestic terminal
Sydney is a very interesting airport, but currently its characteristics are still not prominent, and it has been almost a year since its launch. It should be slightly repairedAt least make three runways available like IAD. And adding missing parking spaces, as the number of parking spaces is currently limited and there is a shortage of personnel.
Which 3 runways do you want to make available?
I do agree with the missing parking spaces
You can’t use the cross runway when the other 2 are active. The same as with PRG…
The cross runway at SYD is only used with bad weather or maybe maintenance on the big runway.
That was before, airport operations had already changed, now。Now it’s divided into time slots, and three runways are available.
Hi all, I’ve been playing WOA for a while now but this my first post here.
For SYD I believe the current Pax stands I11 and I12 should be changed to be combined gates. IRL they regularly see Texel Air / TGE 737 freighter movements. I also agree with other posters that additional cargo stands should be added to the jet base side of 16R/34L which are primarily used by DHL and friends.
Just adding a quick post onto this whilst I’m doing a little bit of tidying up in the gameplay suggestions. This request was implemented in 3.2.0.
