[ATC] - Towing
Towing aircraft from bay to bay this would mainly be from remote bay to contact bays.
This would be only for your own aircraft, could work by giving you an option to tow to a contact bay that has just become available but only if you havnt started handling.
This would be more of a realistic feature not really much benefit, but could be an added feature to also tie in to maintenance ie you have to purchase a hangar at each airport and when aircraft are due for maintenance they need to be towed to the hangar then once complete towed back to bay.
Great suggestion.
Just to clarify a bit that I’ve also seen towing at my local airport (DUB) mainly to push them away from terminals and parking spaces all the way to the end of the taxiway and close to the turning point to start there engines.
