CNN - Sharepoint
Use this thread to share your screenshots from CNN.
You wouldn’t think this is a generic airport. It’s AMAZING
Well, bought the ERJ135 and had 4gp left over, i see this as a long term investment ;p
Cool with the Czech 737 in the hanger
Well, maybe not at a glance
But if you put the fact it’s supposed to be CNN, many issues arise….
Maybe not but as I had seen someone put. You compare msfs generic airport textures to this then CNN is infinitely more detailed
Well I understand that statement there is one major issue.
In msfs you spend more time in the air than anywhere else, but in world of airports you spend your entire time at the airport. They almost need to give it more detail than what msfs would have because you spend so much time there. The excuse of having more detail than a flight simulator is a little bit null and void the way I see it
the textures arent the point of generic airports. They will all have good textures. What the generic bit means is that they all use the same assets, which is why this looks nothing like the actual CNN, and why you see a czech 737 in the hangar
First time seeing 25 being used :slightly_smiling_face:
Was a nice surprise this morning. i like it a lot the swap round
Can’t wait to see this at INN/BRI/PRG
I have a Question can i only used the wheelchair truck only for event planes
or also naormal planes like A321
all planes, slightly more likely on bigger planes but it’s just random
Depends where because I get them mostly at CNN and even smaller planes get them
