Can devs maybe think of pimping the connection system a bit to make it more interesting to use? It’s pretty boring after you’ve reached the achievement once since there is no incentive to keep the connection running and furthermore you are earning even less than if you serve traditional airlines while wasting landing slots (which is essentially important at single runway airports).
It can be scaled a bit like the WoA-golden arrival, so that the more you play the more you have to serve but it would be still something you can focus on.
Another thing that should be rewarded is the handling of player aircraft where you don’t have a connection partner. Right now I’m rejecting big aircrafts from other players which happens a lot at SAN & PRG because the few L&XL-stands are not worth it being wasted with an A380 from player xy where I just get around 2500w. Maybe the 2-step-award-system could be changed to the existing single player strike with your connection partner and a total handled player aircraft (connection partners and others)?
The connection thing is the only social ingame interaction between players and it’s a cool thing that should maybe get a bit more attention. What do you think?
