Due to the change in Structure of the Site, we are moving the connections threads over to this new Category. In Order to find the connection airport you are looking for you will need to use the tag system. At the top of the connections category, you will see Category format of
World of Airports - Connections - Tags
Under the Tags option, select the airport you are looking for and the relevant threads will appear.
If you are create a NEW thread. please ensure you use the tag for the airport code. INN, BRI etc. and Connections, so that people searching from elsewhere on the site can find these.
As a reminder for new threads you will need to include the following information
Create your own thread for new requests.
Identify routes needed (BKK, SYD etc.)
Make sure your Username is on the request
Confirm size of planes available and # potentially available
Tag your thread with the airport code (like INN) and “Connections”, so that people can find it.
When requests are accepted to your needs, please LOCK your thread, by selecting the wrench and selecting “Close Topic”, do not keep threads permanently open.
I might just be slow, but I can never actually find the wrench to close the topics. Can someone help me?
I actually don’t know if you have the ability to do so without TL4, but on your own posts only it might be possible. Wrench icon can be found by clocking the three dots on any post or comment
Where are the three dots tho
Oh wait, I see it and the wrench, but the only option is to make it into a wiki post…
Can no longer edit my own post on this thread. I need to update my plane availability so as to avoid doubling up contracts with other players. Sending/receiving @ MCT classes C and higher (Airbus version)
This is unfortunately a site restriction. @carlsberg72 can probably give exact numbers, but there are different trust levels, and users at trust level 0, 1, and 2 cannot edit past certain amts of time. Trust level three (which gives the regular tag) and TL4 (leader) are the only two that have unlimited edit permissions. Can get around it in short term by asking a TL3 or 4 to edit your post for you or just add comments. I did make the post wiki to make it easier for high level users to edit it, but that’s all I can do unfortunately.
Ok thanks. Initially on a previous post in the same thread I was able to edit the OP. I wasn’t sure of it was a bug .
