I just attach the screenshot below:
According to WoAinfo, XPs required for the same level at different airport should be exactly the same.
I can recall it was very difficult to progress after LV81 at BKK, so it might be changed recently.
Can anyone confirm this or have any idea on it?
PS: I would say if the XP for each level will dramatically increase after Lv100 for all airports (the same growth before Lv100 and then it just +5000 from XPs required for Lv99 > Lv100, so to be 7000 XPs or something…), could be better for OCDs like me…
Yeah. At some big airports like IAD, BKK, and LHR the xp per level after level 80 jumps to around 5000, almost 6000 for level 89 at IAD. It’s miserable lol. For some reason that doesn’t happen at SYD.
I wouldn’t mind grinding it if I got an interesting contract but it’s a couple of CRJ’s at LHR. Would love another 20 levels at LHR after unlocking SYD which are just cool retro liveries for BA
Yeah, I already knew it will be very hard after Lv81. But my point is that things seems to be different at BKK and it has been changed, probably recently.
The XP needed to Lv83 should be 5,272 but 1,318 at BKK (like LHR), and only BKK.
I have no idea what’s happening…
(I know it’s a old post)
I feel it wierd that LHR having a single landing runway (Almost 1/3rd capacity based on speed) is having 5000+ XP per level but BKK having almost similar or even better landing capacity like IAD has just 1500 XP per level which is actually nothing, you just need to complete 5-15 contracts which would need max of 2 hours whereas IAD would need 7 to 10 hours per level
Probably thinking about it from another way and that would make some sense?
The exact level that starting to require significant more XPs to the next level can be treated as the point of [Might be the End of this Airport].
So yeah, the point where BKK ends could be at a higher level.
But what I feel people are looking for is a unified scheme. So beyond what I mentioned to make every airport being that crazy at Lv100, it would also be possible to have different starting points (but the number added to the XP for leveling up will increase respectively for airports with later starting point, like small airports at Lv 50 and +2,500, medium airports at Lv 75 and +5,000, large airports at Lv 100 and +7,500 and if there is beast there could be another one like Lv 125 and +10,000 but starting from there you see a different reward scheme like 1 GP for every few levels or even every level maybe).
At LHR and IAD, past level 80 follows the linear function while at BKK the quadratic function is used.
The XP requirements seem to not be calculated automatically and are likely hardcoded into the game. Aside from the above being an evidence for this, another colloboration is the incorrect BRI XP required on level 50 which was fixed about 9 months ago. Furthermore, the pre-2.0.1 XP requirements did not seem to follow any sort of calculation, and it was after they adjusted the XP with the help of a calculation did it seem like it was calculated by the game itself
