Diminishing returns
I have 3 doubts which need urgent attention from my dear aviation friends around
1.) LEVEL 67 at IAD what i observed now is all my own A388 profits from Netherlands or any european countries started ri diminsh from 13k all way down to 9k in their tier 8..why is it so ? Am i doing something wrong?
2.) If i decide to csncel contrsct and look for a better place it will take away all the xps i gained from all this time
3.)I purchased A388 now and when checked a plsce the entirr map wad blank apart from only Los Angeles being shown why is it so?
How can i maximize profits please assist snd guide me cheers…thankzzz
My ID is :Sultan18786
  1. You will keep the XP you already gained from that contract but once reassigned the contract will restart from level 1
  2. Change the seating arrangement of the A380 in the hangar when unassigned and put the number of first class and business seats up
As for 1 i don’t know but someone else may have the answer
This is ervery time, after finishing the contract Level (for example 2/2 or in your case 7/7). The reward for the first trip of a new extended contract (0/3 or in your case 0/8) is lower. If the plane come back with contract level 1/3 or 1/8 the reward increase again to the usual hight.
Hi there @Bharat
  1. It might be the seating configurations and due to the demand between airports. If not, then someone can answer.
  2. If you get rid of the contract, the XP you previously earned will be with you, but when you start over you will start up like you started ur previous contract at level 1.
  3. Your seating maps will be the main reason for finding airports to send ur A388. I also suggest finding a good seating map and saving that reference as it will help u find the airport you wanted.
Hope that is helpful. With effecient profits would be just looking at profitable airplanes that can get you the best revenue between your playable airport and someone elses or a destination airport.
I Use a Boeing 767-400 from sydney SYDand so i look around on airports for good revenue and then I add a seating map to configure for best revenue.
Japan tokyo or henada = round trip = 2000K plus Wollars
Singapore = round trip = 2000K plus Wollars
Kaulu Lumpur = Round Trip = 2000K plus Wollars
Bankok = round trip = 2000K plus Wollars
Hi, shld i cancel the exisitng contract where returns are less snd look for better options?
Also help me ubderstand how to check seat map priort allocating the plane
I don´t now. For answering this question I should see your contracts, your settings for the aircraft and also your rewards. If you like you could suscribe the discord channel from WOA: • Discord | #:man::laptop:developers-corner | World of Airports, there it is possible to stream, that i can see your problem or i could show you, how I manage my contracts.
I try now to explain, without stream, how I am working to find an optimum AI contract with own planes. First I select the aircraft I want to buy in the shop. Then I set seat configuration first and business, so it is possible to set approximately the double amount for business.
But that means not to find so the best value for reward. Final desicion I do in the map. With high settings in first class, the distance range increase. But the amount of possible airports you can find contracts decrease, because a lot of them have less demands. So you have to change maybe several times the slider for settings of seat configuration. You can do this in the map also, as you know. I show it with an example for a B77W to look for a contract from my BKK to AKL (Auckland New Zealand).
I choose the airports for contracts for the own fleet so, that the amount for maintenance don´t exeed 7.2. This is the amount in the picture for the value “Wartung bei Hin- und Rückfahrt”. I choose airports which demands is in all setting positions (first, business and economy) higher than the airplane can deliver! We can see now, that AKL request 15 passenger for first class. So I change the settings and observe, if rewards from 3487+ “Einkunft pro Hin- und Rückflug” will change.
sometimes the rewards increase, if you choose not the highest possible amount for first. In this example you can see the setting for 13 first class is better!
This increase could also be for the settings of business, so you have to try out. So I could find maybe one of the best contract values for a B77W from BKK to AKL like this:
If you choose contract, which amounts of maintanance is higher than 7.2, so the costs for this service increase and the wollar rewards per flight decrease. You can see this for example I am looking for the same plane for a contract to SAN:
The amount for maintanance is 9.41. That means you have to pay for big service of 187000 Wollars when you reach at least contract level 8/8. With settings of 7.2 it is possible to reach the highest amount of possible contract level 10 and the expensive service is due after you have reached contract level 10/10 the first time.
So I hope I can help you with that a little. See you in the skys and have fun. For more questions write me a PN (personell message) at the chat, then we could make an appointment maybe for stream if necessary…
Thank you so much for the support
Thanks for the help. I am in college and so i would have taken off a homework for that XD
sure and minimum 1 ECTS Point :rofl:
ECTS? huh
for your studies :grin:
Nicely written, thanks :smiling_face_with_sunglasses::flexed_biceps:
But it seems quite complicated to me. I would rather search for airports by earnings and the plane would automatically adjust the number of seats.
It is quite tedious to search for the ideal seat position at several airports, but at the same time I have a problem because I do not operate planes at the airport and they lose time.
Yes, that would be easy and I would prefer it too!!
