With the implementation of the new version the flight distance from NGO to AUH has changed significantly. Seems to be a bug if you compare it with close by DXB.
Since airplanes no longer fly in straight lines and take stops in between, some routes are longer than others. You’re right that this route seems a little suspicious.
@kubasan is this ok?
Fixed.
@kubasan this issue is present again in 1.26.8
