Expand realistic flight contracts and improve runway traffic management
I would like to see an expansion of the number of realistic flight and aircraft contracts available in game, together with improved runway traffic management
The goal would be to make airport operations more representative of real world aviation while giving players more control over how traffic is handled at larger and busier airports
This would include:
More realistic passenger routes and aircraft contracts
More realistic cargo routes and aircraft contracts
More airline destinations, particularly across asia
More Cathay Pacific and Cathay Cargo contracts at HKG
More realistic cargo rotations and multi sector operations
The ability to influence or select which runway an aircraft uses for landing and takeoff
Better distribution of aircraft between multiple available runways
I am aware that there are existing suggestions regarding local/regional widebody operations. This suggestion is intended to address the broader lack of realistic routes and contracts, as well as runway traffic management, rather than simply duplicate that proposal
The existing contract system could be expanded with a larger database of real world airline operations.
For example, at HKG, Cathay Pacific and Cathay Cargo could have more of their real destinations and aircraft represented
This could include:
Additional mainland china destinations
More asian destinations
Multiple aircraft types on the same route where applicable
More cargo destinations
More realistic cargo aircraft contracts
The same approach could eventually be applied to all airlines and airports
Cargo aircraft could also have multi sector rotations instead of every contract being treated as an isolated A to B flight
For example:
HKG - PVG - ANC - ORD - ANC - HKG
This would make cargo operations much more realistic and give cargo aircraft more interesting utilisation
Another improvement would be giving players more control over how aircraft move on the ground, rather than relying entirely on the games automatic ATC system
At larger airports, many available taxiways are currently underused while aircraft can become concentrated around the same runway or taxi route. This can create unnecessary congestion and long waiting times
Players could have the ability to influence:
Which runway an aircraft uses for takeoff and landing
Which direction an aircraft uses for takeoff or landing, where the airport and wind conditions allow it
Which taxiway or taxiway route the aircraft uses
Which direction the aircraft takes when entering or leaving a runway
Which direction an aircraft performs its pushback
Which taxiway an aircraft uses after landing to reach its stand
Which taxi route a departing aircraft follows from its stand to the runway
For example, if an airport has several parallel taxiways, the player could direct aircraft through different routes instead of having almost all aircraft use the same taxiway
Similarly, when an aircraft is parked at a stand, the player could select the pushback direction so that the aircraft ends up facing the most efficient taxiway
The system could still have automatic ATC, but players could optionally switch between:
Automatic ATC - Assisted ATC - Manual/Advanced ATC
The automatic system would remain the default for players who don’t want to manage individual aircraft
For advanced players, however, manual or assisted control could allow much more efficient traffic distribution
This would make the airport feel much more like an actual ATC/ground operations management system, rather than simply watching aircraft follow predetermined paths
It would also give players a reason to learn the layout of each airport and optimise their ground operations
Another improvement would be allowing players to choose or influence which runway an aircraft uses
At larger airports, the game can sometimes concentrate a very large number of aircraft on a single runway while other available runways are significantly underused
This can result in situations where 50+ aircraft are effectively waiting for the same runway, creating extremely long queues and causing aircraft to take a very long time to land
A runway assignment system could allow players to distribute traffic between the available runways
The game could still automatically prevent unsuitable choices based on factors such as:
Wind direction
Runway length
Aircraft type
Airport restrictions
Runway availability
The player would therefore have more control without being able to make unrealistic runway assignments
An alternative could be an automatic traffic balancing system that distributes aircraft between available runways according to their capacity and current traffic
These changes would improve both realism and gameplay, especially at large international airports
For the contract system, many real world airline operations are currently not represented in sufficient detail. HKG is a particularly good example because Cathay Pacific and Cathay Cargo operate a very large network throughout mainland china and asia
Adding more realistic contracts would:
Give players more realistic route options
Make better use of the aircraft already available in the game
Increase variety in airline operations
Improve cargo gameplay
Make airports such as HKG feel more complete
Allow players to recreate realistic airline networks
Improved runway management would also become increasingly important as airports become busier
Instead of having aircraft queue behind dozens of other aircraft waiting for one runway, players could actively manage traffic and distribute aircraft across the airport’s available runway capacity
This would make managing a busy airport much more strategic and satisfying.
Most importantly, these changes would not necessarily need to make progression easier. The existing progression, aircraft unlocks and contract requirements could remain unchanged.
The main objective would simply be to give players:
more realistic operations + more realistic routes + better control over airport traffic
Some examples:
stand - pushback direction - taxiway selection - taxi route - runway selection - takeoff
landing runway - exit taxiway - taxi route - stand
These screenshots show actual Cathay Pacific/Cathay Cargo operations at HKG, including
A330, A350, B777 and B747 operations to destinations across mainland china, asia and long haul markets. They also demonstrate multi sector cargo operations such as HKG - ANC - ORD - ANC - HKG and LEJ - BLR - HKG - GYD - LEJ
