F28 - Fokker F28 Fellowship
F28 Fellowship by Fokker
C
The F28 Fellowship is a twin-engine, short-range jet airliner designed and manufactured by Fokker which was designed for commercial aviation, and while not exclusively a military design, it was adaptable for military and government use due to its ability to operate from smaller, less-equipped airports, which made it useful for short-range transport and the movement of VIPs.
Fokker F28 was significant for being a successful early jet airliner that made jet travel accessible to smaller airports, and for pioneering the regional jet market. There was a special feature for the F28 which is the application of a “speedbrake” which was built into the tail. An application that was only common in military aviation and enabled the aircraft to descend effectively and quickly.
There are no Fokker F28 aircraft currently in civil service. Some of the historic operators include the following:
:france: Air France
:papua_new_guinea: Air Niugini
:australia: Ansett Australia
:indonesia: Garuda Indonesia
:spain: Iberia
:south_korea: Korean Airlines
:germany: LTU
:netherlands: Martinair
:norway::sweden: :denmark: SAS
:saudi_arabia: Saudia
:türkiye: Turkish Airlines
However they’re are a few F28 still active as a military/government operators which include:
:argentina: LADE
:colombia: Colombian Air Force
:philippines: Philippine Air Force
F28-1000:
The first version of the F28 which has one of the short body subtypes and there is one overwing emergency exit on each side.
F28-1000C:
It is similar to the F28-1000 except for the cargo door in the left front fuselage.
F28-2000:
A fuselage stretch of somewhat more than two metres resulted in the F28-2000. Even though it is modestly longer than the F28-1000, this is still cearly visible.
F28-3000:
Compared to the F28-1000, which has the same fuselage length, the F28-3000 has a 1.5 m wider span.
F28-3000R:
The F28-3000R is the same as the F28-3000, except with the weight and performance limitations of the F28-1000.
F28-3000C:
This is the same as the F28-3000 but then with the cargo door of the F28-1000C.
F28-3000RC:
The F28-3000RC is the same to the F28-3000C as the F28-3000R is to the F28-3000.
F28-4000:
F28-4000 combines the long fuselage of the F28-2000 with the wings of the F28-3000, it has two emergency exits on each side, the only F28 variantto have these.
F28-6000:
The final F28 variant was supposed to be an F28-2000 with short field performance, the two aircrafts built were later converted to F28-2000.
F28 Wikipedia
F28 Operators
F28 History
F28 Variant Recognition
F28 Skybrary
F28 Landing/Takeoff Youtube
F28 Review Part 1 Youtube
F28 Review Part 2 Youtube
F28-1000
F28-1000C
F28-2000
F28-3000
F28-3000R
F28-3000C
F28-3000RC
F28-4000
F28-6000
I think the Fokker 28 should be put in B class, as it is actually smaller than the Fokker 70.
It should by the fuselage size but ICAO code is determined by wing span, so this is why F28 is determined to be a C class airplane
:melting_face: But Fokker 70 have been put into B class in the game and Fokker 28 is smaller aircraft than Fokker 70.
If that’s the case, it would be a final say for the devs to decide the ICAO code, if they’re going to add into the game - I put it down as a C class as the post template asks for it to be classified by the ICAO wingspan, but if there going to add it as a B class aircraft, I’m happy to be wrong here :smiling_face:
Yeah, I still have no idea what their standard is for aircraft.
Not sure either - but it seems to be either fueslage size or wingspan size?
Since doing my LAN Ecuador post, I was looking on jetphotos of the old Quito Airport, discovered a small airline called Icaro,
I ended up going down a bit of a rabbit hole trying to find the fate of a certain aircraft HC-CDT, which had an accident due to a rejected takeoff and collision with ILS equipment. The aircraft was DBR but it wasn’t all that badly damaged and no one was injured so it was put on display at a hostel in Salcedo,
A little thing I like doing is going looking for these displayed/abandoned aircraft, all beginning with the hundreds dumped across Brazil, and I noticed it vanished off Google Earth in the late 2010s, supposedly being moved to Santa Isabel. Anyway, still can’t find it in its new spot but discovered this cool page detailing Ecuador’s history with the Fokker aircraft including the above.
If we’re going off a 2010 cutoff point for airlines and liveries, the only airline outside of small African ones that operated it was Biman who kept theirs going till late 2012, though if this was pushed back to say 2005, it would open up a lot more operators such as Tame and some Indonesian airlines, plus if we get a South African airport, SAA Express operated them until 2008.
I love Tame’s livery and it really suits this aircraft,
Such a lovely little aircraft and it would be fantastic to see it one day.
Biman kept their F28s because they were a viable aircraft at that time for transport to smaller cities in Bangladesh. In the 1990s, Biman had taken up at least three BAe Aerospace ATPs to mainly replace the F27s, but the aircraft weren’t very reliable and had a very infamous record, along with the F28s. However the F28s weren’t replaced due to the fact that there wasn’t a good replacement for them, eventually in 2012 they had replaced them with the DHC-8s, mainly because of the aging aircraft (Some of which were 40 years old), an insufficient supply of parts, and not enough aircraft for a consistent schedule.
