Fleets and airports
Hi can someone please explain the positive reasons for owing a fleet,I just don’t get it the planes seem to cost more to run. Also on an unrelated topic on sending planes to airports I don’t fully understand the info panels telling you what the airport requires.Hope that made sense….Tanks fir any help
Your own fleet gets way more profit then AI planes, for example B77W can get up to 12,000 Wollars per flight
Thank you ….i also find it difficult to know which airports to send my fleets too .
Id suggest any player airports as there is no initial fee to send them
I was doing that but I found out they were returning empty of passengers
I think its because it’s the first handling, after that I will come back with passengers
Ok I will give a go ….many thanks for help it’s appreciated
Whichever airport you choose make sure you adjust your passenger load to maximize Wollars. The amount you get in return is not the same for every airport.
Thanks do you mean change the seating to get the required business and first class ?
Yes get the most efficient seating configuration :sweat_smile: you can try send to my BKK my id is “LynxDra” I’ll handle it daily
Thanks I will send from Muscat…Lordtimbo name
