Look, it could be anything from King Fahd, to DEN. And from ORD to IST. Airports with huge land areas
I feel like it will work once you have it all round to assigned to gates youāve scheduled. Especially at somewhere like LHR Iām using it as a way where I only assign it a gate once the one from the scheduled system is free. Then once all in sync maybe delivery manager then works properly. Iām not sure
Is that only for player arrivals or for all contracts?
i believe only for player arrivals. Player is kinda rough atm from what ive heard, although ive not used scheduler yet myself.
No itās for normal contracts I donāt have player contracts at Heathrow.
Really? It seems to be working just fine at be SAN?
I tried the scheduling system at LHR, but then I realized that it wasnāt too helpful for your exact reason, so I just decided to go back to the original version. Plus, you have to reschedule aircraft every time you finish handling it, and it becomes available again. When this was first revealed, I thought it would follow a schedule such that it would automatically repeat and form sort of a loop. Thereās nothing wrong with the version now, and itās a cool addition, but I guess Iāll stick with the old version at least for now.
See like you I thought
it be automatic all the time, it doesnāt bother me that I have to keep confirming, though I hope in a future update they make it automatic. Because reason I want schedule for Heathrow is to have the correct airlines at the correct terminals. But I appear to be missing some aircraft like the two I posted, here where they meant to be in the schedule.
Odd then, maybe itās a glitch with Heathrow as I have two missing contracts. And seems on bug report some others are missing contracts there as well.
Donāt do delivery manager as it sends them to random gates. Only ones I do is Arrivals, Departures and Ground.
Has anyone found the easter egg in the garage yet?
The problem with using the wrong model is probably with the previous 752F/752CF, right
Have you saved it, mines working fine.
Edit; landing at LHR in game atm, white dot next to stand means itās not been set or computer did it automatically. Blue means scheduled.
If you see from help screen if they not saved then they are green, mine are all yellow, also found more contracts missing. So I have to carry on with GRU and hope they do some sort of patch that I can return to Heathrow.
Yeah, thatās definitely a reason why I feel like itās not that worth it to sacrifice handling time for scheduling these (because the handling still continues when you have this open).
Where? Is there one?
Apparently in the vehicle garage.
Yet a dev on here few months back when generic airports were announced said it was for smaller airports only, plus as others have said too big airports will be boring, you select tower for 10 mins and first aircraft will still be taxing as tower ends
Hopefully they fix it. ![]()
Iām having problems too. Doesnāt the delivery manager have to be activated for the scheduled aircraft to be assigned to the gate?
Yep, thatās exactly how you do it
