That is my Orange JUICE livery!
How?
Wdym how?
He means how can you get the camera like that while handling, in which you must click the camera angle button in a split second after you assign the crew members. If you leave though, you won’t be able to come back.
Double jetways are now fully operative at GRU along with the broken stand now having a working jetway
I do wonder if this will also be applied to remote stands with stairs and the 757 in the future.
I hope so as well but as someone else mentioned in another post, it might be difficult coding for the 757 and the 767.
I can’t see it being an issue for the 757 as they all have a second door before the wings, the 767 I could see it being an issue with though as they have a mix of door configurations up front.
But from what I notice, it’s based on the plane classes that the L2 door is used and not necessarily each plane, but I could be wrong
But hopefully the devs can find a solution
This is one thing I noticed in the change log, mention of it being large planes (so my assumption was D-F, assuming D can be considered large based on the 767 and A300 being large planes before 3.0).
True, but unfortunately it seem they are considered Large, and also not applied to remote stands as the front door is the one being used with the stairs ![]()
Stair positions weren’t changed I don’t think, just the jetbridges
I feel like they could code it to certain aircraft L2 doors like some 767s and the 757s because I’d think they already have to code each individual aircraft door position anyway (they’re all different distances). In that regard, I think stair position on remote stands would be easiest, because instead of coding a building interaction with the plane, it’s just the planes own local animations for stairs and service vehicles.
Think they might be holding wings a bit!
