Hey there
I need your guys advice, should I get SYD or save the gold planes for an M or an L, I am at level 78 and I have to make a decision on SYD or another aircraft
Do you guys have any advice?
I would unlock another aircraft since you’re so close to SYD anyway. Probably only a few more weeks to a a little more than month before you unlock SYD without GP.
I would recommend B77W or B744, both are very similar in all aspects (except for looks). It seems like you don’t have any cargo though, which in that case I’d get a B77LF or B752F. Neither SYD nor LHR has much cargo space though, so unless you like LEJ might not be a good investment.
Id recommend the 747-400, with player connections it gets me roughly 10,000W a trip. It also has good range and can reach everywhere but SYD from LHR
I unlocked the B77W and the B77LF. I earn about 10.000 W for each roundtrip.
So I do have good use for all my L-Stands.
Ok so what I will do is get the 757F as I have a livery unlocked for it and then I’ll get the 747-400 as it makes a lot of money.
hmmm, I cannot find a B757F
I would recommend the B77W and the B77LF, as you have much more L-Stands than X-Stands and the money you’ll receive is nearly the same.
Since you are so close to SYD, I’d recommend picking a plane that will. help you at SYD!
My 2 favorites for SYD are:
A359 – this is the top L plane in my experience for serving the longest routes in the game (think IAD ↔ SYD and similar). If these are routes you are interested in, I’d recommend it!
B77W – this is the consensus top earner for player planes.
If you want L/X, here are some other planes I think could benefit your fleet:
B748 / A388 – pick the X that you prefer. The 748 is more versatile, and the A388 can earn big bucks on some routes
B788 – this is a great L plane for serving low demand destinations with an L plane like LEJ
If you want to expand your M fleet, these are my recommendations that will open some new doors for you, but if you plan on only playing SYD when you unlock it, I’d recommend no Ms, as they can’t reach player airports.
A21NX – this is the top wollar earning plane for the M tier
B752 – this is the only M plane that can fly between SXM and LEJ as well as SXM and INN. If you have player connections you want for these routes, I highly recommend it, or if you want to serve long distance routes with an M plane, this is the option with the longest routes available.
On cargo – I find that most cargo planes are limited in terms of where they can fly, especially for player destinations, so I personally avoid them.
Its the 757-200F, in game its labeled as 752F
I have the 757-200 but these are great pics, well done!
Change of plan, I’ll get the 777-300 then the 757F then the 747-400. That should hopefully give me a start for SYD.
77w can make up to 15k
Worth clarifying btw the nx isn’t top by a little bit. It’s 4500+ on some routes, which means it approaches some L aircraft. However, if you are paying that much just get a widebody at that point
Fair – the A21N seems to outperform the NX on some shorter routes. I tend to recommend the A21NX just as it flies to a few more player destinations and the difference in profit is minimal enough to me that its pennies haha.
I’d get either the 77W or B744, as they do essentially the same thing. If you want another L I’d recommend A35K as it has the most range of any plane and is great for player connections (especially in the corner of the world with SYD)
Since I’ve seen some folks advocating for the B744, I will point out three things on comparing the B744 and the B77W:
- The B744 does grab a bit more SP and XP on contracts, which is a plus if that’s a priority for you.
- The B77W does grab more Wollars on routes, especially at the edges of the B744’s range.
- The B744 requires 13 handling crew as opposed to 10 for the B77W, so you can only handle 3 744s for every 4 B77Ws. At SYD, this is definitely a downside, but at an airport like LHR, it’s significantly less of an issue as you have a TON of handling crew available.
They both are good planes, just depends on what you value!
