Helvetic Airways E195-E2 (E295) slight livery errors
Platform:
Apple iOS v18.7.8
Game Version:
World of Airports v3.6.0 (6/15/2026)
Airport:
Any European airport (INN, BRI, PRG, ZRH, etc.), or any airport capable of receiving the Helvetic E295
[Airport used below for demonstration is Zurich Kloten / ZRH]
The bugs in question are a small few visual mistakes/errors on the Helvetic Airways E295 - specifically, the ‘l’ in “Helvetic” on the right side of the fuselage is cut short compared to the left side, and the ‘l’ on the left side is also cut short, though not as much (from what it seems like, at least).
Furthermore, on the nose gear doors, registration text ‘AZJ’ can be found - even though aircraft liveries in game usually have no aircraft registration text.
In order to recreate this, buy a Helvetic E295 contract at any airport which can be reached by the aircraft. After which, wait for the aircraft to be allowed to land, at which point you are able to inspect the aircraft and see the visual errors.
(For this report, I’ll be adding on a comparison/reference in the form of a Helvetic E290, which does not appear to have any such errors or bugs - it’s added only for comparison.)
The E295:
The E290 reference:
Additional Notes:
N/A
That cut in the “I” isn’t a bug in the livery; it’s because the letter is above the window. Besides, no airline in the world paints letters or any element that’s part of the airline’s identity or brand above the windows. That characteristic you mentioned can also be seen on the Air Caraibes A35K, for example, and on some other airlines I can’t recall.
It seems to be a bug, there is a noticeable difference between the left and right sides of the plane.
Hello @traincrashed,
Thank you for the detailed report! We have reviewed it and forwarded it to our DevOps team for investigation.
We will look into this and aim to address it in an upcoming update.
