Hi everyone, I have played WoA for a month and I noticed my iPhone gets high temperature easily after playing WoA for an hour.
Do you have the same situation? How do you usually mitigate it? Or did devs ever do any battery usage optimization?
FYI I am using iPhone 12 with iOS17.6.1
One way you can avoid it is turning the graphics settings down.
“Pretty” graphics is for strong, powerful phones or if you only play about an hour or two every so often in the day.
“Balanced” is for regular phones and for playing long hours on standard or powerful phones.
“Fast” is for older phones and generally the lowest graphics setting, used really only if your phone is super weak.
I’d suggest to set it to Balanced for now and see how it acts.
My iPhone 12 (or 13?) would get pretty hot if I played long, but my iPhone 15 doesn’t, so perhaps it’s an iPhone optimization issue and not necessarily the game.
iPhone 16 pro, doesn’t get hot but preupdate it could run 10+ hrs straight of Syd and now under 2.5 hrs of bkk
Thank you all for replying!
I am already using the “Balanced” mode, and I turned off the 3D landscape toggle. I will keep observing.
