I alr have this route with the exact same plane but for some reason I can just purchase it again
Infinite 757’s
That’s pretty cool
But you should probably make the devs aware
Maybe it’s a reward plane or a transfer contract?
It’s not necessarily a glitch. That contract was from the awards pass. Usually, if you anticipate the destination of the awards contract, you can buy it first in the normal contracts tab, and then also claim it as a second copy from the pass. I’ve not seen it the other way around, but I’d imagine the mechanic allowing to you purchase a second copy is BECAUSE it’s originally a pass reward contract as well. Using this trick I’ll double up on regional and international contracts for fun, but it does cost that extra SP since they are awarded before you unlock the respective ratings. I guess it could still be worth reporting to the devs. Support@flyboys.games
