Incorrect callsign Kenn Borek Air
Platform:
Encountered on iOs
Game Version:
3.1.1
Airport:
SXM
When handling the Kenn Borek DHC6 at SXM I noticed an incorrect callsign on ATC. When it’s given a command the callsign you hear is FREEDOMSOMALI, when you expect to hear BOREK AIR.
n/a
Additional Notes:
Likely due to fact that 4K designator is also used by Freedom Airline Express (Somalia). IATA.org shows 4K in use with the Somalian airline, other sources say Borek Air is 4K (incl. the Borek Air page). Freedom Airline Express uses ICAO 4F for its Kenya-based operations.
Even Flightradar24 seems to be confused and uses the Freedom Airline Express name on flight 4K201. With an A320 flight listed in Africa and BE20 flights in Canada. But also the 4K link with Kenn Borek Air - though no flightnumber - for the real life aircraft from the event.
Hi, thanks for reporting. This issue has been resolved and the fix will be included in the next update, version 3.4.1. :airplane:
