INN stand 10 pushback doesn't work
Platform:
Android
Game Version:
3.5.0
Airport: INN
After handling an Air Lingus A21NX at stand 10, I clicked the pushback button, but the aircraft didn’t move. I departed all aircraft in the queue that could have blocked the aircraft from pushing back but there are still some airplanes that can’t get past this A21NX because it is blocking the taxiway behind it.
Get a long queue of aircraft that want to depart at INN and click pushback on a A21NX at gate 10
Screenshots:
hi, i was about to create a bug report like this when i stumbled upon your post. just saying that you aren’t the only one who experienced this; me and some other dude on Discord experienced this as well
You don’t need a long queue
The plane is just stuck there, eventually it will pushback but it will cause a long queue
I’ve noticed after all planes before it have landed/departed, it will pushback after a while
You don’t even need a queue. Had a plane ready to push with absolutely nothing behind it except a e170 bound for stand 11, which was still near I want to say stand 3 when I clicked pushback. It never did move and the e170 stopped where the saudia is in your screenshot
Its just during the first phase, the first wave of D planes use the “old” parking pattern. The next wave will use the “new” tillted parking patern and the airplanes can pass.
I’m a bit clueless
What does this mean? Lol
the planes waiting for landing have still the “old” parking path. The new arrivals will have the “new” tillted parking position.
that’s not the problem though? the problem is that a plane won’t pushback….
example being here, the Atlantic air hasn’t pushed back for almost a minute now
it pushed back about 30 seconds after I took this screenshot, I think there’s something wrong with the timing, or the collision detection is in the wrong place, I don’t know
Update: I FIGURED IT OUT!
So basically, all planes that are behind stand 10 waiting to lineup are registered as an obstruction until they despawn after takeoff, which then the plane in stand 10 will pushback. at least when 26 is in use, have not tested with 8 due to winds only giving it use while I was at work
So this will continue to happen, its has nothing to do with the old parking pattern, right?
I think it registers arrivals also as obstructions cause I’ve experienced a plane not pushing back until the landing one was vacating the runwa
I haven’t noticed this with landing in 08
We will check it
Reported fixed 3.5.1
