Keep xp gains
Good afternoon friends, I would like to make a suggestion so that we can have reasons to play at all airports. One of the main objectives of the game is to beat the levels that are in each airport, since when we complete it, the most that makes us play that airport again would be to help other players with flights. My idea is, even after beating the last XP level, to continue accumulating XP since each update usually brings new levels. Would that be possible?
It is a great idea that I support.
You can try to post it in [Features Request] section.
I’d rather have the XP converted into SP after reaching max level.
I’ve brought this up a few years ago but apparently that beats the purpose of additional levels later on that the built up XP would boost you to whatever level you accumulated XP to
I don’t see the point in going back to a smaller airport, for example BRI INN or PRG, since it’s worth it, but I’d only be playing LHR, which is an airport close to the others, with many more flights and boarding gates to use. Now, if I accumulate XP for future new levels after updates, then I would go back to playing all the airports, instead of focusing on just a few. I think it would be good for the DEVS to think about this.
I think getting like a buffer XP would be a bit gamebreaking, you can unlock an airport, even before its released. I think there can be a different way, like getting more silverplanes when XP is full.
