LHR or LEJ
I have enough GPs to unlock LHR and LEJ, which should I choose? Since both had duo runway landings. Cause I wanted an airport that can hold lots of L or X planes.
LHR is better in every aspect except for cargo.
You can still get it
LHR, it’s a much bigger airport with much more space for L/X aircraft making it a great airport to grind sp.
LHR definitely, bigger airport, more stands, more money. Still has a large cargo terminal aswell
Honestly I’d say LEJ for dual landings. Being bigger isn’t necessarily better, and you can far more sp at lej than lhr, plus it’s dramatically faster to level up. If you are on android, you can see a guy called Defoe has like 15 accounts in the top 100, and the way he does it is by exclusively grinding LEJ. Lhr is honestly way overhyped, earning potential at LEJ is close to 2x
Edit to add: the reason bigger isn’t better is because while it’s true that it has tons of stands, you can’t even come close to filling it if playing actively. This means the only real benefit is more handling crew, and there’s enough at LEJ.
LEJ.
Different from the others, more money, dual landing, better grinding.
LEJ but it needs more handlers. Like many more.
100% you should get LHR. Can make the most Wollars and collect SP nicely.
Lej is better for both
I don’t think he likes cargo aircraft lol. My A380s would complete 3-4 flights before he’d send back the freighters. :rofl:
He went with LHR.
Honestly because of my bias I would pick lhr because it is fun playing on an airport I’ve visited many times but without bias for sure lej because you can get so many local L planes and cargo planes give better rewards
