MSY - A6 stand
Very difficult to choose S-M ou L stand … Bug or normal behaviour ?
It’s a feature called shared stands implemented in 2.6.0. You can park 2 S/M or 1 L/X in the same stand.
You can choose the M stand by filtering for M stands on the left. Without setting a filter it’s difficult (near impossible) to touch the field.
I think the post is not about the shared stand but about that it is nearly impossible to build the S M stand because the interaction field of the L X stand is directly above it. A workaround is to select only M or S stands in the construction menu.
I personally wish there was another UI, I made this for the new UI suggestions, but may as well share it here:
true
This topic was automatically closed after 30 days. New replies are no longer allowed.
