[Other] - 767-300 second door loading
Accepted prefixes:
  • Other – for anything not covered by the above (e.g. tutorials, accessibility, languages)
Some 767-300’s feature a second door before the wings depending on customer preference and country’s regulations. These doors are used for loading and unloading, sometimes being used in conjunction with the front door as per other aircraft types.
Jetbridges will connect to the second door or first on the 767-300 variants with two forward doors. They could also just be modelled like the 767-400’s where both doors are used but it would be nice for randomised between the three options as irl the 767-400 sometimes only uses the one when both are available.
What improvement would this bring? Better usability, realism, fun factor, accessibility?
Greater realism and differences between different 767 variants operating
Azerbaijan’s 767 loading at the second door,
British Airways being loaded, top at second door, bottom at first door (Top is a lot more common though),
Qantas using the front door,
Thomson at second door,
I think devs only made one jetbridge connection preset for B763 because different door configs are still considered one variant. I don’t know if making this happen will have to make a plane into two or more separate variants.
I presume that’s the case yeah. It’s also less common, at least with the liveries we have in-game as most only have the 1 forward door. I’m also not sure if it would make it a second variant, would be interesting to find out from the devs about that.
